Goertzel for stm32f103 LCD
What are you developing?
stan
Post by stan »
Hi
This program is working fine with arduino uno, for blue pill there is compiling error. I looked at Goertzel.h but I didn't find something special which can cause the problem.
Here are, program, error, Goertzel.h file.
// Set things up
//http://play.fallows.ca/wp/radio/ham-radio/signal-analysis-morse-decoder/
#include <Goertzel.h>
int sensorPin =PA6;
//int sensorPin =A0;
int led = PC13;
//int led = 13;
//const float TARGET_FREQUENCY = 500;
const float TARGET_FREQUENCY = 5000;
const int N = 100;
const float THRESHOLD = 4000;
const float SAMPLING_FREQUENCY = 8900;
// Create the filter
//Goertzel goertzel = Goertzel(TARGET_FREQUENCY, N, SAMPLING_FREQUENCY);
void setup(){
  pinMode(led, OUTPUT);
   goertzel.sample(sensorPin);
// Check samples for tone at target
   float magnitude = goertzel.detect();
// if the tone is present, light LED
   if(magnitude>THRESHOLD)
     digitalWrite(led, HIGH);
   else
     digitalWrite(led, LOW);
     // Serial.println(magnitude);
error
Arduino: 1.8.8 (Windows 10), Board: "Generic STM32F1 series, BluePill F103C6 (32K), STLink, Enabled (generic 'Serial'), None, Low/Full Speed, Smallest (-Os default), Newlib Nano (default)"
A subdirectory or file sketch already exists.
In file included from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\cctype:42:0,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\bits\localefwd.h:42,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\string:43,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\stdexcept:39,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\array:39,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\tuple:39,
from c:\users\galinka\appdata\local\arduino15\packages\stm32\tools\arm-none-eabi-gcc\6-2017-q2-update\arm-none-eabi\include\c++\6.3.1\functional:55,
from C:\Users\Galinka\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.5.0\cores\arduino/WInterrupts.h:25,
from C:\Users\Galinka\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.5.0\cores\arduino/wiring.h:39,
from C:\Users\Galinka\AppData\Local\Arduino15\packages\STM32\hardware\stm32\1.5.0\cores\arduino/Arduino.h:32,
from C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:19:
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:26:5: error: expected unqualified-id before numeric constant
int _N;
In file included from C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:22:0:
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp: In constructor 'Goertzel::Goertzel(float, float, float)':
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.h:26:14: error: lvalue required as left operand of assignment
#define MAXN 200
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:48:9: note: in expansion of macro 'MAXN'
_N=MAXN;
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:50:8: error: lvalue required as left operand of assignment
_N=N;
exit status 1
Error compiling for board Generic STM32F1 series.
Goertzel.h
  The Goertzel algorithm is long standing so see
  http://en.wikipedia.org/wiki/Goertzel_algorithm for a full description.
  It is often used in DTMF tone detection as an alternative to the Fast
  Fourier Transform because it is quick with low overheard because it
  is only searching for a single frequency rather than showing the
  occurrence of all frequencies.
  This work is entirely based on the Kevin Banks code found at
  http://www.eetimes.com/design/embedded/4024443/The-Goertzel-Algorithm
  so full credit to him for his generic implementation and breakdown. I've
  simply massaged it into an Arduino library. I recommend reading his article
  for a full description of whats going on behind the scenes.
  See Contributors.md and add yourself for pull requests
  Released into the public domain.
// ensure this library description is only included once
#ifndef Goertzel_h
#define Goertzel_h
// include types & constants of Wiring core API
#include "Arduino.h"
#define MAXN 200
#define ADCCENTER 512
// library interface description
class Goertzel
  // user-accessible "public" interface
  public:
    Goertzel(float,float,float);
    Goertzel(float,float);
	void sample(int);
	float detect();
  // library-accessible "private" interface
  private:
	void GetRealImag(float*,float*);
	void ProcessSample(int);
	void ResetGoertzel(void);
Answers: 92
Re: Goertzel for stm32f103
Firstly, update to latest release 1.9.0.
Edit:
In fact you used _N while it is a definition in ctypes.h:
#define	_N	04
stan
Post by stan »
With new IDE the error is;
Arduino: 1.9.0-beta (Windows 7), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STM32duino bootloader, 72Mhz (Normal), Smallest (default)"
In file included from C:\Users\John\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2017.8.5\cores\maple/WString.h:28:0,
from C:\Users\John\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2017.8.5\cores\maple/wirish.h:47,
from C:\Users\John\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2017.8.5\cores\maple/Arduino.h:30,
from C:\Users\John\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:19:
C:\Users\John\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:26:5: error: expected unqualified-id before numeric constant
int _N;
C:\Users\John\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp: In constructor 'Goertzel::Goertzel(float, float, float)':
C:\Users\John\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:48:8: error: lvalue required as left operand of assignment
_N=MAXN;
C:\Users\John\Documents\Arduino\libraries\Goertzel-master\Goertzel.cpp:50:7: error: lvalue required as left operand of assignment
_N=N;
exit status 1
Error compiling for board Generic STM32F103C series.
feluga
Post by feluga »
stan wrote: Wed Dec 16, 2020 11:14 pm error
The problem is in the board you selected. Use BluePill F103C8 instead of BluePill F103C6 (32K).
Change it on Arduino IDE menu "Tools" --> "Board Part Number:" option.
Answers: 92
The main issue is that you used _N in your code as a variable name while it is a statndard definiton in ctype.h of the toolchain.
Simply change it and this will work...
feluga
Post by feluga »
fpiSTM wrote: Thu Dec 17, 2020 5:47 pm The main issue is that you used _N in your code as a variable name while it is a statndard definiton in ctype.h of the toolchain.
Looking at Goertzel.cpp, there may be another potential problem, beside the compiling issue you pointed with _N, regarding CPU Frequency:
Goertzel::Goertzel(float TARGET_FREQUENCY, float N, float SAMPLING_FREQUENCY)
  _SAMPLING_FREQUENCY=SAMPLING_FREQUENCY;	//on 16mhz, ~8928.57142857143, on 8mhz ~44444
  _TARGET_FREQUENCY=TARGET_FREQUENCY; //should be integer of SAMPLING_RATE/N
  if(N>MAXN){
     _N=MAXN;
  }else{
    _N=N;
  float omega = (2.0 * PI * _TARGET_FREQUENCY) / _SAMPLING_FREQUENCY;
  coeff = 2.0 * cos(omega);
  ResetGoertzel();
This may demand some "manual" adjusting of MAXN and N... Thus, even if it compiles right, it may not work properly.
stan
Post by stan »
so I made modification
// Set things up
int sensorPin =PA6;
int led = PC13;
//int led = 13;
const int N = 100;
int coeff;
 int goertzel;
  if(N>MAXN){
     N=MAXN;
  }else{
    N=N;
  float omega = (2.0 * PI * TARGET_FREQUENCY) / SAMPLING_FREQUENCY;
  ResetGoertzel();
void setup(){
   else
and error is;
Arduino: 1.8.12 (Mac OS X), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STLink, 72Mhz (Normal), Smallest (default)"
/Users/Documents/Arduino/goertzel_org3/goertzel_org3.ino: In function 'void loop()':
goertzel_org3:46:13: error: request for member 'sample' in 'goertzel', which is of non-class type 'int'
goertzel_org3:48:31: error: request for member 'detect' in 'goertzel', which is of non-class type 'int'
exit status 1
fredbox
Post by fredbox »
Replacing _N in Goertzel.cpp as advised by fpiSTM allows the example program to compile without error.
This will probably need more work to actually do something useful as the CPU frequencies are quite different between the two processors.
26 int _Number;
48      _Number=MAXN;
50      _Number=N;
Sketch uses 23944 bytes (36%) of program storage space. Maximum is 65536 bytes.
Global variables use 1696 bytes (8%) of dynamic memory, leaving 18784 bytes for local variables. Maximum is 20480 bytes.
stan
Post by stan »
Thanks it is done, no errors. For some reason I have higher space usage
Sketch uses 25352 bytes (38%) of program storage space. Maximum is 65536 bytes.
Global variables use 3960 bytes (19%) of dynamic memory, leaving 16520 bytes for local variables. Maximum is 20480 bytes.
stan
Re: Goertzel for stm32f103 LCD
Post by stan »
it is compiling but not working I added LCD, in uno LCD it is alive in stm32 it is dead just displays 0.00 and do on respond to signal on PA6.
// Set things up
int sensorPin = PA6;
int led = PC13;
//int led = 13;
const int N = 100;
#include <LiquidCrystal.h>
LiquidCrystal lcd(PB15, PB5, PA2, PB6, PB8, PB9);
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
    lcd.begin( 16, 2 );
  if (magnitude > THRESHOLD)
  else
  lcd.setCursor(0, 0);
  lcd.print(magnitude);
Return to “Projects”
