program modification
stan
Post by stan »
I modify this program to have on OLED "Hello World "
viewtopic.php?f=7&t=402
On serial monitor I have it but OLED is black = what to do ?
//https://www.stm32duino.com/viewtopic.php?t=402
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
TwoWire Wire2(PB11, PB10);// OLED
Adafruit_SSD1306 *display;
  Wire2.begin();
  Wire2.setClock(400000);
  display = new Adafruit_SSD1306(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire2); // OLED
  while (!display->begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
    delay(500);
  display->clearDisplay();
  display->dim(0);
  display->setTextSize(1);
  display->setTextColor(WHITE);
  Serial.println("Hello World");
  display->setCursor(0, 0);
  display->println("Hello World");
  display->display();
Re: program modification
Maple Mini I2C (5 year old Adafruit libs)
#include <SPI.h>
#include <Streaming.h>
#include "./Adafruit_GFX.h"
#include "./Adafruit_SSD1306.h"
#include "./BMP085.h" // #include "I2CDEV.h" is pulled in also
// These pin #'s are for Maple Mini
//     __Signal__Maple_//__OLED 128x64___
#define OLED_CS   14   //   ---   x Not Connected
#define OLED_DC   22   //   D/C   pin# 6
#define OLED_RST  21   //   RST   pin# 5
#define OLED_MOSI 20   //   SDA   pin# 4
#define OLED_CLK  19   //   SCL   pin# 3
Adafruit_SSD1306 OLED(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST, OLED_CS);  // OLED object
Full ZIP compiles on current IDE (unknown if OLED works, I cannot find my OLED parts box at the moment.)
Sketch uses 28036 bytes (22%) of program storage space. Maximum is 122880 bytes.
Global variables use 4472 bytes (21%) of dynamic memory, leaving 16008 bytes for local variables. Maximum is 20480 bytes.
SPI_OLED_BPM180.zip
(25.31 KiB) Downloaded 259 times
stan
Post by stan »
The idea is to use I2C2 = PB10, PB11.
STM342F103.
stan wrote: Tue Jan 26, 2021 12:36 am The idea is to use I2C2 = PB10, PB11.
STM342F103.
IF you are using the Libmaple (Roger's) core:
https://www.google.com/search?&q=I2C2+s ... oforum.com
If you are using the Official core, maybe check out the WiKi.
i've not worked with SSD1306 but the Adafruit tutorial may be useful
https://learn.adafruit.com/monochrome-o ... s/overview
there is a datasheet in the downloads page, keep it handy
but u'd need to find out if the lcd is responding over the i2c bus
i2c has an ack response, one of those ways is to find out in the i2c code if there is a way to print (or insert your own print statement) some debug output when the oled is connected.
among the things you need to be sure that your oled is at the correct address
https://learn.adafruit.com/i2c-addresses
try the different address like 0x3C and 0x3D
Answers: 92
You van use i2c scanner example from the wire library example.
stan
Post by stan »
When I connect OLED to PB6 and PB7 I have address 0x3C,
When I connect it to PB10 and BP11 I have this;
scan 10.png (14.9 KiB) Viewed 5240 times
Can someone do similar scanning and show the results, does not have to be OLED, can be LCD16x2 with I2C .
Franke39
Post by Franke39 »
The number of connections/wires needed is determined by the OLED display. The Adafruit ones have a dedicated connection for reset, (and may also have optional SPI) BUT the cheaper ones don't. I am using one of the cheaper ones and it has 4 connections: ground, Vcc, SCL and SDA.
When you asked for a "scan" I assume you are asking for the results of a I2C scanner. Most I2C scanners I see, are for the Uno/Nano type boards and only look for one I2C bus. If you use that type of I2C scanner, it doesn't know to look on the second I2C bus (SCL2 @ PB10, SDA2 @ PB11)... It will only show the first I2C bus (SCL1 @ PB6, SDA1 @ PB7)
If you want to use the second I2C bus you need to add these lines before setup()
 #define OLED_RESET -1 // use -1 if no reset pin on OLED board
// use second I2C bus on STM32F103
// TwoWire Wire2(SDA2, SCL2);
Adafruit_SSD1306 Display
// below is for a 128x64 OLED. Other option is 128x32 for smaller OLED
(128, 64, &Wire2, OLED_RESET);
Then after setup():
   Display1.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // if nothing is displayed using 0x3C, try 0x3D
  //  Display1
  Display1.clearDisplay();
  Display1.setTextSize(2);
  Display1.setTextColor(WHITE, BLACK);
  Display1.setCursor(0, 0 );
  Display1.println("Display");
  Display1.println("I2C #2 @ 3C");
  Display1.display();
I hope this helps :)
stan
Post by stan »
I did this way and have an error
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire_slave.h>
//use IIC2
//TwoWire WIRE2 (2,I2C_FAST_MODE);
//#define Wire WIRE2
  Wire.begin();
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  nDevices = 0;
  for(address = 1; address < 127; address++) {
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
      nDevices++;
    else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found");
  else
    Serial.println("done");
  delay(5000);           // wait 5 seconds for next scan
  //  Display1
  Display1.display();
error
Arduino: 1.8.12 (Mac OS X), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), Serial, 72Mhz (Normal), Smallest (default)"
i2c_scanner_wire:38:25: error: no matching function for call to 'TwoWire::TwoWire(<anonymous enum>, <anonymous enum>)'
In file included from /var/folders/yj/fygyw1t57zggv9lf50h08zr80000gn/T/arduino_modified_sketch_609513/i2c_scanner_wire.ino:27:0:
/Users/Documents/Arduino/hardware/Arduino_STM32-master-3/STM32F1/libraries/WireSlave/src/Wire_slave.h:91:3: note: candidate: TwoWire::TwoWire(i2c_dev*)
TwoWire(i2c_dev* i2cDevice);
/Users/Documents/Arduino/hardware/Arduino_STM32-master-3/STM32F1/libraries/WireSlave/src/Wire_slave.h:91:3: note: candidate expects 1 argument, 2 provided
i2c_scanner_wire:40:1: error: 'Adafruit_SSD1306' does not name a type
i2c_scanner_wire:90:4: error: 'Display1' does not name a type
i2c_scanner_wire:93:3: error: 'Display1' does not name a type
i2c_scanner_wire:94:3: error: 'Display1' does not name a type
i2c_scanner_wire:95:3: error: 'Display1' does not name a type
i2c_scanner_wire:96:3: error: 'Display1' does not name a type
i2c_scanner_wire:97:3: error: 'Display1' does not name a type
i2c_scanner_wire:98:3: error: 'Display1' does not name a type
i2c_scanner_wire:99:3: error: 'Display1' does not name a type
Display1.display();
exit status 1
Franke39
Post by Franke39 »
What do you want to do?
Scan the second I2C bus, or use the second I2C bus?
The code above is a jumble of setting up the second I2C bus and scanning the first I2C bus.
