Compile error for board Generic STM32F4 series.
nawasaqi
Post by nawasaqi »
Hi to all,
I have such a problem. I bought a new computer and installed Arduino on it and I would like to compile with Serial, I have an error
c:/users/backu/appdata/local/arduino15/packages/stmicroelectronics/tools/xpack-arm-none-eabi-gcc/10.3.1-2.3/bin/../lib/gcc/arm-none-eabi/10.3.1/../../../../arm-none-eabi/bin/ld.exe: core\core.a(HardwareSerial.cpp.o):(.bss.Serial2+0x0): multiple definition of `Serial2'; sketch\iBus.ino.cpp.o:(.bss.Serial2+0x0): first defined here
exit status 1
#include <IBusBM.h>
IBusBM IBusServo;
HardwareSerial Serial2 (PA3, PA2);
  Serial2.begin(115200);
  IBusServo.begin(Serial2);
  ibusServo();
void ibusServo()
 // show first 14 servo channels
  for (int i=0; i<14 ; i++) {
    Serial.print("Ch");
    Serial.print(i);
    Serial.print(": ");
    Serial.print(IBusServo.readChannel(i));
    Serial.print(" ---- ");
 Serial.println("Next");
  delay(2000);
Can anyone help me what am I doing wrong ??
Re: Compile error for board Generic STM32F4 series.
Serial2 may already be there, trying commenting the definition and rebuild
Answers: 92
Serial is an alias to a default Serialx instance. In your case, it is probably Serial2 by default. So change the name you used and check that PA2 and 3 is not the one used by the default one. Which variant you used?
