SD card access via SPI
cagz
Post by cagz »
I am trying to get SD Card working, using SPI on an STM32L052K8 board (custom built).
Following code is simply giving initialisation error (simply fails at SD.begin stage).
Do I need to do anything else STM32 specific here ? Especially in terms of which SPI pins this MPU uses (but I suppose that's defined in STM32duino headers ?
I appreciate any idea on how to troubleshoot next. Wirings are double-checked but attaching a copy of it as well in case you see something obvious.
#include <SPI.h>
#include <SD.h>
File myFile;
 Serial.print("Initializing SD card...");
  if (!SD.begin(PA8)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    myFile.close();
    Serial.println("done.");
  } else {
    Serial.println("error opening test.txt");
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  } else {
Screenshot 2023-08-03 at 13.41.42.jpeg (63.61 KiB) Viewed 1086 times
by fpiSTM » Fri Aug 04, 2023 7:51 pm
If you used generic then you probably need to redefine pins used for default SPI instance. See the wiki for this:
https://github.com/stm32duino/Arduino_C ... tance-pins
cagz
Re: SD card access via SPI
Post by cagz »
Seems like I am the only one on the forum who had an SD card problem, I must be doing something really silly.
So far I tried smaller SD cards, a battery instead of USB thinking it might have been a voltage issue, but no luck.
There is a passive buzzer just next to the SD card slot. When the SD card is in, I hear a hiss from the buzzer and click when the device powers up. Can't tell if it is EMI or voltage drop causing this, but it is not resulting in a brownout. Tried to power the board from a 2S LiPo battery instead of USB to let it take whatever amps it needs but no difference at all
Answers: 92
cagz
Post by cagz »
It was exactly this and it only needed:
SPI.setMISO(PB4);
SPI.setMOSI(PB5);
SPI.setSCLK(PB3);
Thanks a lot for your help !
