Set frequecy pwm
paulocapel
Set frequecy pwm
Post by paulocapel »
Hi, guys.
i'm noob with stm32
I have a problem. i use the library dan.drown.org and i'm not able to use the hardwaretimer.h.
wanted to change the frequency of the pwm for 25khz with variable duty cycle.
I haven't worked with the timers of stm32 yet.
library
https://github.com/rogerclarkmelbourne/ ... Serial.cpp
https://github.com/rogerclarkmelbourne/ ... reSerial.h
Can someone help me please ??
Re: Set frequecy pwm
try the examples here
http://docs.leaflabs.com/static.leaflab ... dwaretimer
duty cycle has to do with
TimerX.setOverflow(Y)
http://docs.leaflabs.com/static.leaflab ... r.html#id2
cross reference RM0008 on timers
about output compare mode and pwm mode. the duty cycle is controlled by the capture compare register CCRx
which is the library called it the 'overflow'
Answers: 8
Have a look here: viewtopic.php?p=1752#p1752
